Ricoh MPC2050 color registration problem
  • raveendrala
    • Oct 2016
    • 80
    Hello,
    I got Ricoh MPC 2050 , It is Color registration off . I tried clean ITB, ID sensors and SP2-111-3 (rough), then SP2-111-1 (fine) several time task complete but result same.
    Any help would be great,
    Thank you
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Ricoh MPC2050 color registration problem
    Make sure all the drums are screwed in.
    What is the result of SP2-194-007, and SP2-194-010 to 012?
    You could have a faulty ITB or ID sensors.
    • copier tech
      • 8172
      Looking at your sample, why is the paper so wavy, did it exit the machine like that?
      • Lenovich
        • Jul 2017
        • 17
        I see the paper is wavy. The Fusing Units in the models are quite sensitive. Could be the fusing unit is causing this especially as you have already tried line adjustment and it is not working. I have had countless problems on these units if the paper is damp, especially if the machine is near a window with no air-conditioner and near the sea (on the coast).
        Check that the paper is a good make of paper and not recycled .
        I found damp paper causes the wavy effect and also colour offset. if you are in a hot clmate i suggest moving the machine to an air conditioned area to test it and see if this helps.
        Failing that put another fusing unit in just to check if this solves the wavy issue.
        I have had to change Complete Fusing Units here on the Coast to resolve wavy paper, colour offset and Toner rubbing off on envelopes. (Even though I spent a day making adjustments according to Technical Bulletins-nothing helped. Only complete Unit replacement solved all the issues.)
        • Mark Bbb
          • Jun 2012
          • 1662
          While color registration is done by a mirror adjustment in the laser housing unit, it could be a problem in there...
            • 37532
            Are you sure that sure that forced line position is nor ending in an error? Yellow appears far enough off to prevent forced line position from working.
            It looks to me like you or someone else at your location did either a memory all clear (SP 5801-001) or engine memory clear (SP 5801-002). If you do not have the birth certificate or a non default print from before the problem started, you may have to do a manual line position adjustment.
            • raveendrala
              • Oct 2016
              • 80
              Yes It is recondition machine it was memory clear by sale person can u let me know how to do a manual line position, forces line position end with out error
              • TonerMunkeh
                Professional Moron
                • 3865
                If you look under the front cover you may be lucky enough to have the birth certificate in there. Re-input all the values and it should bring line position back into adjustment enough that the machine can adjust it from there.
                Oh, and tell the "sales person" he's a fucking idiot.
                Hit it.
                • Lenovich
                  • Jul 2017
                  • 17
                  Typical Salesperson! Yes man made faults can be the most difficult to find!
                  • kannuki2
                    • Feb 2012
                    • 398
                    I am not sure if Ricoh still keep birth certicate on file at corporate location for 7years. It doesn't hurt to call them up.
                      • 37532
                      You will have to change values in SP 2101. The original values would be on the birth certificate. If you do not have the birth certificate, it then becomes a trial and error adjustment. Since the yellow is the farthest out, start with it. Change the Y Main Scan Dot. Print the color test pattern. Check which way the yellow has moved. Repeat using different values until the yellow moves in the correct direction. If changing the main scan dot moves the yellow along the wrong axis, work with the sub scan dot. Once the yellow is close, repeat for cyan and magenta. Once all three are close, run forced line position to finalize.
