MP4001 ADF Jamming in inverter
  • TayTayTheTechnician
    • May 2016
    • 51
    ^^^^ video of what it's doing.^^^^
    J004 misfeed
    I checked the one way bearings in the doc feed. New feed belt but I dont think that has anything to do with it. I checked to see if there were any cracked gears and couldn't find any. It is only jamming when copying duplex. It is a notoriously dusty/dirty machine.... not sure if that is pertinent info? any help would be very appreciated.
  • LNorris
    • Sep 2008
    • 645
    Re: MP4001 ADF Jamming in inverter
    Where is the paper inside the adf when it jams? is that blue guide broken?
      • May 2016
      • 51
      It's right in between the exit rollers, I did not notice if the blue guide was broken but it didnt appear to be. That is, it lifts and closes during jam removal without feeling wonky and visually I know the pegs that go into the front and back frame arent busted. According to a phone call from my end user, it is now jamming regardless of simplex or duplex.
        • 37556
        Your video is nice but doesn't tell us anything. You would have been better to have posted the jam code.
          • May 2016
          • 51
          HA just realized that attachment didn't save. my bad, J004 ​is the code.
            • May 2016
            • 51
            It's a few different codes, here is the first page of the smc also
            Thanks!SKMBT_C55417082818260.pdf
            • jonhiker
              • 661
              Clean all of the sensors. Also, remove the rear cover and check the end of the exit roller. there is a gear back there that i have replaced before for the same issue.
                • 37556
                Lead edge of the original is catching on something in the reverse path from the exit roller to the skew correction roller. After it jams, you need to check where the lead edge has stopped. Also check the ribs on any plastic guides for burrs.
                • ColinLouw
                  • Jun 2017
                  • 26
                  20170829_152400.jpgHad my days with a mp4001 adf!
                  clean and make that black again with black permanent marker. it did solve my problem..
                    • May 2016
                    • 51
                    I have coated all the sensors and checked the guides for obstruction. I will double check the gear! Thanks!
                    Sent from my LG-LS777 using Tapatalk
