MPC6501 doesn't save the changes in SP mode
  • Guest
    [Misc] MPC6501 doesn't save the changes in SP mode
    Hi
    when i try to change SP 2108 from 0 to 1 , the machine doesn't save changes after reboot
    so after switch the machine Off and on , All values return back to the defaults
  • trc
    • Jan 2007
    • 95
    Re: MPC6501 doesn't save the changes in SP mode
    Nv-Ram
      • 37375
      Which color are you trying to switch off and why?
      • Guest
        I have a customer need to use the machine as black and white only ..
        and i need to be far away from any code related with color
        " I know how to print as black and white , also i can use the permissions to prevent the users to copy in color "
        The problem not only in this case but many SP program in this model "MPC6501" Like 2201
        after i switch the machine off return to the defaults
        Thank you for fast reply
          have you tried telling the print driver to print in black only?
          • Guest
            Thanks for you all to replay
            But still i have a problem to keeping the values after switching the power OFF in many Sp code
            Like
            2201
            2108
            The main question is How to change the value in SP2201 or SP 2108 from the default value to other value and force the machine to keeping those values after switching off
            Thank you again, i already using MP black driver for printing and grant permissions for coping in color
              • 37375
              Like
              2201
              2108
              My guess is that SP 2108 is for testing purpose only. SP 2201 is labeled as DFU which mean Design Factory Use. Stop trying to so things that the machine is not designed to do.
              • Guest
                Not marked in the service as DFU
                And stable in mpc6000
                • ruben
                  The New Guy
                  • Oct 2012
                  • 1203
                  Why not just turn on user authentication, and restrict colour copying and printing? You go the whole way and create a user code that has colour authority, and the customer can decide who has use of it. There should be no need to mess around with SP modes, when all they want is basic restriction.
                  Either that or side-step to a B&W only machine.
                  • Guest
                    Thanks Ruben..
                    All answers concentrate into how to stop printing or copying in color " I can do this "
                    I'm focus into how to Chang in SP mode like sp2201, I'm using this SP as the instruction manual with sp3301 to control the the image and clear the dark background specially with BK
                    with MPC6000 , i can change 2201 the the machine saving the new numbers
                    but with MPC6501 after switching of all bombers return to the defaults
                      • 37375
                      First your original post had to do with SP 2108. If your problem is back grounding, you should have started with that and asked how to correct that. That is easy to answer and does not require f***inf with SP settings that have very little to do with causing back ground. SP 2201 and SP 3301 are not related. Changing 3301 to fixed is to be used when the toner density sensor on a development unit has gone bad, and only until you get a new development unit. In fixed mode, the machine will tend to overtone and thus increase back ground. To correct for back ground, follow these steps:
                      1. Clean and inspect the drum unit. If there is less than 10mm left on the lubricant bar, PM the unit.Same applies to the ITB cleaning unit and the PTR unit.
                      2. Apply all bulletins dealing with image quality and toner dropping. There are quite a few for the C6501 which is a toner belching beast by nature.
                      3. Partially change the nature of the beast by changing the correct SP settings. The ones you are using are not the correct ones. See the attached starting with page 10. This document was given to me by our then regional support person.
                      Service Program (SP) Settings.pdf
                      • Guest
                        [ATTACH]37523[/ATTACH]
                        Thank you for your support, I'll reed and give you the feed back
                        • SargeNZ
                          • May 2012
                          • 263
                          DFU to me always meant DONT F***ING USE
                          • Guest
                            Thank you slimslob
                            your Pdf help a lot
