Hi.. I've just replace the new drum but the machine still sending message "replace photo conductor unit". please help me to clear the message.
Thanks!!!
I don't know the product code, the machine model is Ricoh Aficio MP2590, 25ppm. I think is 25xx series or so.
I think some SP mode should be done after replacing the drum unit but don't know away to enter SP mode.
I also try clear mode > 1 0 7 > clear/stop but no help. What should i do then?
Look at the model plate behind the bypass door, there will be a product code. MP2590 is not a valid number and CM107CS should work on all Digital Ricohs
sigpic
A+; Network +; PDI+
oh my good! the MP2590 doesn't like those ricoh digital copiers in the way of entering SP mode. I've already tried Clear mode > 1,0,7 > hold Clear/stop but no help, the machine answers "beep beep" but nothing happen so I couldn't enter SP mode.
anybody know how to enter the MP2590 SP mode?
MP 2590 is the same machine as MP2510 3010
Entering and Exiting SP mode
Press the Clear Mode key.
Use the keypad to enter “107”.
Hold down Clear/Stop for at least 3 seconds.
Enter the Service Mode.
To enter the Normal Service Mode:
Copy SP On the touch-panel, press Copy SP.
To enter the Special Service Mode:
Copy SP Hold down # and then press Copy SP.
Exit Press Exit twice to return to the copy window.
If you cannot go into the SP mode, login as Admin with no password go to User Tool and then set “Service Mode Lock” to OFF. After Login
[User Tools] > System Settings > Administrator Tools > Service Mode Lock > OFF
This model MP2590 is for Asia, so you not american.
The Russian-C4 and C4.5 are a bugger for not recognising they've had a new PCU installed.
If you put a new one in and it still asks for one, run SP2-801 (I think, might be 2-804) developer initialisation. Replace PCU message will disappear. It's not a good idea to turn the PCU alarm off as most customers won't know how often the PCU needs to be replaced and will just put in a service call for copy quality issues.
true, but the PCU will go alot longer than 60k, which is the default alarm setting. you can raise the setting, but i find it easier to just go when the customer calls for copy quality. its cheaper on parts and if the customer isnt that picky about CQ, then the PCU will last even longer. FYI- that PCU is rebuildable and doesnt need to replaced as a whole unit
