SC 544-00 MP C4502
  • maikel safwt
    • Nov 2014
    • 58
    SC 544-00 MP C4502
    I have an error code SC 544-00 MP C4502 I changed the fuser and made the 5810-01
    and 3902-014 and still the same
    in the service the fuser is over heated but the old one is still in a perfect condition no thing damaged and when the code appear again the fuser still cold i checked the output voltage to the fuser lamp from the IH-Inverter board its 0V i didn't change it yet.
    any suggestions
    please if any one have the service manual in English his efforts will be appreciated
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: SC 544-00 MP C4502
    SC544 is reset with SP5810-002.
    Hit it.
    • maikel safwt
      • Nov 2014
      • 58
      failed message is appear
      • TonerMunkeh
        Professional Moron
        • 3865
        Was it a brand new fuser or one from another machine? If it's a used one it will be missing the reset fuse that a new fuser or fusing sleeve has. Fit it, then 5810-002 will complete allowing the code to be reset.
        Hit it.
        • maikel safwt
          • Nov 2014
          • 58
          in my country i didn't have the new fuser i checked by used one
          but the machine fuser is in a very good condition i need to know what the problem happen and still make that code appear
          • TonerMunkeh
            Professional Moron
            • 3865
            As mentioned in my previous post you require the reset fuse that comes with either a new fuser or a new fusing sleeve to reset this code.
            Hit it.
            • maikel safwt
              • Nov 2014
              • 58
              The old fuse is ok ,and i disconnect a fuse from an other fuser and connect in the original machine fuser and the same result, I think the overheat dosn't happen in my condition .
                • 37513
                • maikel safwt
                  • Nov 2014
                  • 58
                  i change it from a machine in a good condition and nothing happen is there is a difference between the new fuse and the used one
                  • Coptech
                    worker drone
                    • 460
                    Yes, once the fuser is installed in any machine, good or bad, it immediately pops. The only purpose for that fuse is to tell whichever machine it is in that you installed a new fuser. Once it is installed and powered on, the fuse is a goner. But it is no longer needed in theory.
                    • maikel safwt
                      • Nov 2014
                      • 58
                      oh i see , but there is a manually detection for the new fuser 3902-014
                      is that resolve this issue ?
                        • 37513
                        No. That will just automatically reset the PM counters if there is a good fuse on the new fusing unit.
