Aficio 2051 (b+w) with sc555 + sc552
  • axyun
    • Aug 2007
    • 1323
    Aficio w error sc555 + sc552. Cust had sc555 and knows
    Spmode reset. Did reset snd got sc552. Won't reset. Do i need
    thermistor or lamp as per SM.? Frank/AP
  • COPIERMAN
    • Jun 2009
    • 559
    Re: Aficio 2051 (b+w) with sc555 + sc552
    if you have a spare fuser take that with you. If not then take thermistor, heater lamp, over temp sensor, upper fuser and lower pressure roller, bearings both upper and lower. Hope that will get you going. Could be a board problem too wont know till you get there and check it out.
    • axyun
      • Aug 2007
      • 1323
      Thank you for your quick reply Copierman. Unfortunately i don't
      Have mich for that machine . Have thermistors + other parts
      not related to fuser. Frank
      • jonhiker
        • 661
        I would start with the thermistors and thermostats.
          • 37529
          • Polarbear
            • Feb 2012
            • 1070
            Hi
            Seems like you are looking at a busted fusing lamp for both codes, or a lamp and end thermistor.
            SC 552:
            Heating roller warm-up error 2
            seconds after the fusing unit has rotated.
            low temperature condition after the heating lamp on.
            Heating roller fusing lamp broken
            Defected thermostat
            1. Check if the heating roller thermistor (end) is firmly connected.
            2.
            Replace the heating roller thermistor (end).
            3. Replace the heating roller fusing lamp.
            SC555:
            Heating roller lamp consecutive full power 2
            When the fusing unit is not running in the ready condition, the pressure roller-fusing
            lamp keeps ON full power for 130 seconds or more.
            Broken heating roller fusing lamp
            1. Replace the heating roller thermostat.
            2.
            Press the GREEN button!!
            • axyun
              • Aug 2007
              • 1323
              Thank you Copierman, Jonhiker ,Slimslob and Polarbear. So very grateful for your help. Turned out to be one of the thermostats. Frank
              • anothertech
                • 1771
                Dirty thermistors usually cause that.
                • axyun
                  • Aug 2007
                  • 1323
                  Got lucky. with thermos fuse. Easy enough to take care of. Thanks. frank
                    • 37529
                    In my experience they are seldom the cause since they are normally replaced at each fusing unit PM. I have had to replace a lot more thermostats due to fusing errors.
                    • kannuki2
                      • Feb 2012
                      • 398
                      I had one with 5.2 millions pages kept throwing that error codes - sc555, sc542, sc543. I had to replace the IOB to resolve it.
                      • anothertech
                        • 1771
                        What I mean to say is that dirty thermistors cause the fuser to over heat and that is what causes the thermostat to blow.
                        Ricoh should go to a non contact thermistor.
                          • 37529
                          They did with the 1060 and 1075. They scraped it with the 2060/2075 and subsequent models.
