Ricoh SP 5200s (M052) Constant "Add Paper"
  • ivanthegeek
    • 9
    Hey Everyone. Has anyone seen this before?
    We have a customer who installed a Maintenance Kit that included the fusing unit and feed rollers ect... Since then, all 3 of the optional trays are in a constant "add paper" state. It looks like they installed everything correctly. I tested all of the sensors with input check and they check out fine except the trays don't seem to raise enough to trigger the Paper End Sensors.
    I can't see inside the tray area to tell what is preventing the paper from raising all of the way up.
  • copier tech
    • 8144
    Re: Ricoh SP 5200s (M052) Constant "Add Paper"
    My customers break the out of paper sensors all the time but I doubt yours have broken all 3!
    Does it feed from bypas?
    Try lifting the machine offthe paper back & reseat.
    • ivanthegeek
      • 9
      Yes the bypass and the 1st tray works.
      • copier tech
        • 8144
        Lift the machine off the paper bank check the connection block.
        Updating the fw may help.
