Repeated prints
  • tonnerboy
    • May 2011
    • 212
    Repeated prints
  • copyman
    Owner / Technician
    • Sep 2005
    • 4701
    Re: Repeated prints
    Maybe problem is just very big PDF files and they are taking a long time to spool and print. Perhaps you can add more memory or HDD if it doesn't have one?
    Also try different driver, maybe use postscript if using pcl.
      • 37490
      Re: Repeated prints
      Is there a jam occurring when it stops? I have heard of machines restarting print jobs after a jam caused by defective cover switches on a bridge unit.
      • sandmanmac
        • 3981
        Re: Repeated prints
        This is almost always due to Windows 10 auto installing/re-installing the device on the WSD port rather than tcp/ip, and it's most noticeable with PDF files. They can be BRUTALLY slow.
        Can someone please explain the benefit of this port to me? All I've ever experienced is dreadful performance. Is there any benefit at all?
        It took me a long time to figure it out, but I finally got smart, and disabled the WSD features via the WIM for all my installs going forward.
