Mp4054
  • lejaunek@motswako.biz
    • Aug 2016
    • 1
    Mp4054
    Hi i have a mp4054 that was up for pm changed drum ,dev ,blade after 2 weeks the prints became very light. Did a rtb that was out for adjustment of vsg and vsp still nothing. Changed the TD sensor it worked for about 4 months and now the prints are light again anyone else have the same or similar problem.
  • aktasson
    • Feb 2017
    • 201
    Re: Mp4054
    After replacing of pcu/dv the developer initalization was executed?
    Did you try forced toner supply in sp? And how was the result of printout?
    Does the toner bottle rotate (toner bottle motor) in outup check?
    I use the whole pcdu D2020125
    • copier tech
      • 8103
      Re: Mp4054
      You say it lasted 4 months but how many prints had been done in that time? 100? 100,000?
      • ESTANISLAOWENENTON
        Re: Mp4054
        If what others have advised you, such as checking the toner motor, toner hopper, initial developer and drum setting and have already done it, I would tell you to clean the magnetic roller and every streak of it.
        on several occasions something similar to your problem has happened to me and this has solved
        • davel
          • Oct 2011
          • 1079
          Re: Mp4054
          Did you initialise the dev, what about charge roller and cleaner?
          • blazebusiness
            SanDiegoCopierRepair.com
            • 1250
            Re: Mp4054
            You did the right thing by changing SP3-629-001 (Vc Vsp) to 530 SP3-629-101 (Vb Vsp) to 330
            Was there any improvment after you did that procedure?
            Did you follow the proper procedure by going into service mode before you changed the developer? That model only initializes properly if you set the SP code for developer replacement before you replace the developer.
            Before replacing the developer, set the setting of SP3-701-024 to “1” before turning off the main power. After replacing the developer, turn the machine back on and developer will be properly adjusted.
