SC 583-01 in Pro C7100
  • Ryan18
    • Jul 2025
    [Error Code] SC 583-01 in Pro C7100
    Anyone encounter SC 583-01 in Pro C7100?
    already replaced feed motor cooling fan. same error
  • RG1964
    • Jul 2009
    • 56
    Re: SC 583-01 in Pro C7100
    Check the SC history. If there's a load of SC's you might have a PSU failure.
    Are all the blowers working at start up.
    In my case the machine had a blown fuse on the NYRB board (behind the paperfeedboard) due to a faulty PSU.
    I had to replace PSU nr 6. (in the center of the machine)
    Be carefull to discharge the PSU's first (they will bite you) and remove the mains.
    • Ryan18
      Hi, thanks for the info..
      There's a load of SC's in SC history all code is pointing in Fan. Working blowers only in left door,side of controller board. I already check all the power supply but not the NYRB board. Where is the PSU nr6 located?
      • RG1964
        • Jul 2009
        • 56
        PSU 6 is near the purgetray, you have to slide it out from the back.
        Read the manual, all psu's are connected.
        Have fun
        Took me a few hours to make the right conclusion.
        • Ryan18
          Have fun
          Thanks again.. For the idea.
