RICOH SP4510sf reset completely a copier
  • MelMan
    • Oct 2015
    • 5
    [Misc] RICOH SP4510sf reset completely a copier
    Hello, If any one can help i would appreciate it greatly. I have a RICOH SP4510sf copier, that I picked up on a lease repo and it is brand new with only 6 impression made on it, however it has a code/Password, which i cant seem to clear. I don't want to post anything on here as far as the step i have taken or code i have used only because of the protective comment about none techs on the site. I can say that i have tried some of the steps which have worked with the Ricoh 00, 01, 02 series of machine which has worked on those type of machine but not on this one.
    Admin /no password = failed
    Supervisor / No Password = failed
    Re: RICOH SP4510sf reset completely a copier
    the service manual will have the steps required to clear passwords
      • 37508
      SP 5846-046 in factory SP mode. Otherwise you will have to replace NVram.
      • MelMan
        • Oct 2015
        • 5
        Thank you for the quick response, but i figured it out i was having an "ESTO" error....I working now
        • MelMan
          • Oct 2015
          • 5
          By any chance do you guys know how to set up the machine so that the meter reading is on the op-panel not in the config page?
            • 37508
            There is an SP setting for that.
            • MelMan
              • Oct 2015
              • 5
              Where? I have read the Manual and looked around and i can seem to find it....I did plug in the 1 in the accounting side but the actual Counter button on the copier does not show up
                • 37508
                If by accounting side you mean SP 5045, setting it to 1 will turn off the display counter.
                • MelMan
                  • Oct 2015
                  • 5
                  Sorry once again i had an "ESTO" error for rushing...I just needed to slow down and read...the tiny screen
