af 3035
  • Gab
    • Aug 2015
    • 671
    af 3035
    Can i swap a paper lift motor of 2035 on 3035 machine?
    • 37532
    Re: af 3035
    Are the part numbers the same?
    • Gab
      • Aug 2015
      • 671
      Re: af 3035
      No they are AX040143 AND FOR 2035 AX040078
      • sturmtrooper
        Copier Combobulator
        • May 2016
        • 587
        Re: af 3035
        Precision roller claims they are the same. One may just be an update of the other. I'd say compare the two of them phsyically and if they look the same give it a try. Usually paper lift motors have the voltage, torque, and RPM specs stamped into the casing somewhere. If those are the same or very close it might work.
        Edit: Checked the MyRicoh order page and it shows that the AX040143 is the replacement for the AX040078.
