Rex Rotary pro 1357ex copy quality issue.
  • atech
    • Aug 2010
    • 89
    [Misc] Rex Rotary pro 1357ex copy quality issue.
    I have copy quality issue for Rex Rotary pro 1357ex, the machine indicates toner replacement and both toner banks need new toner as it has two toner cartridge. I only replaced 1 and make a copy..the copy was good but after 2 weeks the copy becomes light. Now I need to run the toner replenishment every time the copy becomes light to make it dark. I am not familiar with this machine although it has similarities with Ricoh aficio 9000. Do I need to replace the developer? I need your valuable advice guys... Thanks..
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: Rex Rotary pro 1357ex copy quality issue.
    What's the meter on the developer and other pm parts? Is the ID sensor clean? Are they using the machine withing the expected volume of use?
      • 37515
      If Toner Supply Mode SP 2208 is set to 1, pixel count, machine will tend to under tone.
      • atech
        • Aug 2010
        • 89
        The total copy is almost 1 million, around 960k. I think the machine has not been replaced with new developer ever since. Is it okay if only one toner bank is filled with toner and the other is empty or do I need to fill both?
        • atech
          • Aug 2010
          • 89
          No, it was set to 0, sensor.
          • sturmtrooper
            Copier Combobulator
            • May 2016
            • 587
            Developer is rated at a 500k life. Given that if it has never been changed the developer could easily be five years old I don't think you'd be out much changing it.
            As for the toner bottle the user manual says to always put new bottles in the lower position first. "Be sure to set the new toner bottle in the lower hole first "
            • atech
              • Aug 2010
              • 89
              In case of developer replacement, I'd like to know the procedure specially during developer calibration, could you provide me simulations.. Thanks
              • Batman1976
                • Jun 2016
                • 91
                RTFM!!!!!
