SCANNING ISSUE MP2852
  • katash
    • May 2010
    • 221
    Hi guys,
    please assist,i have the named machine and cannot scan to mail even though you get connection test successful both for smtp and dns,upgraded the firmware.
    Any ideas?
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: SCANNING ISSUE MP2852
    Check error log.
    • katash
      • May 2010
      • 221
      Originally posted by zoraldinho
      Check error log.
      thanks for that but already done that
      • TonerMunkeh
        Professional Moron
        • 3865
        What SMTP service are you using? Exchange or an online one?
        Hit it.
        • guitar9199
          • Sep 2016
          • 1100
          You might need a firmware update to deal with the SSL changes. Mail providers are starting to tighten security, and the MFP needs to be able to get through that wall.
          EDIT: Just saw you updated the firmware. Here's the list of machines that support SSL Scan to Email...
          • Black & White Multifunction
          • MP 2501SP
          • MP 2553SP, 3053SP, 3353SP
          • MP 301SP/SPF
          • MP 401SPF
          • MP 4002, 5002
          • MP 4054SP, 5054SP, 6054SP
          • MP 6002/SP, 7502/SP, 9002/SP
          • MP 6503SP, 7503SP, 9003SP
          • SP 4510SF
          • Color Multifunction
          • MP C305SP/SPF
          • MP C306ZSPF, C406ZSPF
          • MP C401SP/SRSP
          • MP C2003SP, C2503SP
          • MP C2004SP/SPG, C2504SP/SPG
          • MP C3002/G, C3502/G
          • MP C3003SP
          • MP C3004SP/SPG, C3504SP/SPG
          • MP C3503SP
          • MP C4502/A/G, C5502/A/G
          • MP C4503SP
          • MP C4504SP/SPG, C6004SP/SPG
          • MP C5503SP
          • MP C6003SP
          • MP C6502SP, C8002SP
          • MP C6503SP, C8003SP
            • 37533
            SSL encryption for SMTP connections can be specified by the network administrator.
            To enable SSL encryption for SMTP connections, follow these steps:
            1. Press the [User Tools/Counter] key.
            2. Press [System Settings].
            3. Press [File Transfer].
            4. Press [SMTP Server].
            In "Use Secure Connection (SSL)", press [On].
            If you are not using SSL for SMTP connections, press [Off].
            When "Use Secure Connection (SSL)" is set to [On], the port number is set to 465 and cannot be changed.
            5.
            6. Press [OK].
            7. Press [Exit].
            8. Press the [User Tools/Counter] key.
            If I remember correctly with the MP xx52 models you also need to install a Site Certificate, see attached.
            How do I setup SMTP over SSL on a Ricoh Family group device.pdf
            • StephenB
              • Aug 2015
              • 244
              all the above regarding different SMTP server authentication issues are correct, however a great "go around" is setting up a SMTP2GO account.
              It's free, easy and works incredibly well. ( No I'm not spamming for them ) Just pointing out a great alternative.
              The one drawback, you cannot use a web based email (ie. gmail, etc) for the registration, must use your own domain or ISP assigned email to set this up.
              • sandmanmac
                • 3981
                Agree with you.
                I use SMTP2go quite often myself and recommended it here on many threads as well. Excellent service.
                As for not being compatible with Webmails like Gmail? I've set up a lot, including my own, and never had an issue. Strange that you do
