MP C2500 Transfer Belt Unit
  • mntech
    • Aug 2010
    • 250
    Are there any compatible transfer units that will fit in the MP C2500?
    Like for an SP model printer, that is cheaper and can be easily modified to fit in these?
    New belt is nearly 400 and unit around 600, just looking to do it for cheap if i can.
    Thanks,
    MNTECH
    Re: MP C2500 Transfer Belt Unit
    Thanks,
    MNTECH
    going cheep on that type part will bite you in the ass... pony up
    • davel
      • Oct 2011
      • 1106
      SPC 811 works fine.
      • sandmanmac
        • 3981
        Originally posted by davel
        SPC 811 works fine.
        Agreed.
        Just have to bend a little piece of metal on the rail of the C2500/3500 etc., that otherwise keeps the C811 from sliding in.
        Can't remember where exactly, but it's pretty obvious as I recall.
        Otherwise, it's identical
        • copier tech
          • 8164
          ITB Ass'y 403117
          • mntech
            • Aug 2010
            • 250
            Perfect!
            I know these machines can usually take units from their printer counterparts at a significantly less price tag for am almost identical part.
            Thank you much
            • copier tech
              • 8164
              Perfect!
              Thank you much
              Same for the fuser, complete SPC version fuser unit is cheaper than a rebuild
              • davel
                • Oct 2011
                • 1106
                There is no SPC fuser that is compatible with MPC 2500, only for 35/4500.
                • tufbnme
                  • 493
                  Replace only the belt. Its only a couple hundred bucks.
