Printable area
  • andy227
    • Jan 2013
    • 219
    Printable area
    Guys. When printing a full bleed edge to edge colour copy, the default blank area, is there any way to alter the void/blank area/margin ? I tried the printer service mode sp1-001 ' Prints all RPCS and PCL jobs with a border around the printable area - enable' adjustment, and the margin is no different from the default. Any other way of increasing the margin ? This issue has to do with full full colour copies jamming in the likes of mpc5000's and mpc2500's and I wanted to try a larger blank area to see if that helps.
  • sandmanmac
    • 3981
    Re: Printable area
    I'm not an expert in the area, but I do have a couple of questions / suggestions:
    How much of this type of printing you/ they are doing, because these machines aren't designed to run 100% coverage in large quantity
    Also, Are you using Genuine or compatible toner, and what's the condition of the fusers? Replacing the Oil and cleaning roller in the C2500 will almost certainly help.
    Lastly, I'd suggest that you'll probably have the best luck running that type of job SEF as there will be less paper curl
      • 37532
      Re: Printable area
      SP 2103 Margin Erase. Default values are 2mm for left and right sides and 4.2mm for lead and trail edge.
      If you are running full bleed, I would not change the lead edge erase. It will cause the lead edge of the paper to stick to the fusing belt/sleeve/roller and jam. If you are doing duplex, do not change the trail edge as that will cause the paper to stick to the pressure roller and jam.
      • andy227
        • Jan 2013
        • 219
        Re: Printable area
        These machines are sold to internet cafes for their customers to print on. Wether its one single copy or multiple, you cannot tell the owners that its not designed to do that, it just has to do it for their customers otherwise they seriously gripe. Toner, compatibles, but that is not within our control as techs, it is done by the bosses and we have no say in it. Everyone wants to skimp on costs. We just have to make the best of the situation in front of us and make the machine 'work' using whatever knowledge we have. Condition of fusers, seen better times, but the oil roller was also my thought to do.
        I would have thought that increasing the lead edge erase is better for the lead edge to peel away and less jamming. Thats what I'm trying to do. Thanks both for the input.
        • copier tech
          • 8172
          Re: Printable area
          Replace the fuser sleeves that is your main issue!
          • COPIERMAN
            • Jun 2009
            • 559
            Re: Printable area
            on this model for full bleed turn paper in cassette landscape direction or letter R. copier will work no matter what they are copying.
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              Re: Printable area
              That's like saying you can't tell them to not walk through a wall. Some things are just not possible and no measure of screaming, crying, and tantrums will change that.
              The absolute BEST you can hope to achieve with any laser copier/printer as regards to edge to edge printing is printing to the edge of the three non leading edges and with a small gap on the leading edge so it doesn't stick to the hot roller. How much gap you need will depend on machine and fuser wear.
              If they want real edge to edge printing what they need to do is print on slightly oversized paper and cut the extra off. This is what print shops do.
              Do your contracts not include clauses that require use of genuine toner and not third party crap? If they don't they should.
              If you think the fuser is in poor shape then the best course is to replace the worn parts and adjust from there.
                • 37532
                Re: Printable area
                You can increase the lead edge margin up to 9mm. Also considering the age of both the MP C2500 and the MP C5000 you might need to replace the stripper plate. D0294137 for the C5000 and B2384291 for the C2500. These are coated with a thin layer of Teflon. Once the Teflon wears off, toner will stick and cause jamming.
                • ruben
                  The New Guy
                  • Oct 2012
                  • 1203
                  Re: Printable area
                  The best solution is to purchase an 03 model with the optional Imageable Area Extension Unit, that way a full image can be printed onto a larger paper size and cropped to fit.
                  You can adjust all the edges to almost fit, but you will always have a leading blank edge to prevent jams.
                  • andy227
                    • Jan 2013
                    • 219
                    Re: Printable area
                    Thanks for all the replies. Some may have mis-understood when I said full bleed (my mistake in terminology, sorry) , I mean't simply 'A4 full page print' - solid, with the default blank area, as in a solid photo set to print 'full page photo' option, not true edge to edge. These full page prints tend to jam in mpc5000's and mpc2500's fusers a lot.
                    Slimslob's answer is what I was looking for, SP2103 margin erase, to vary the printable area up to 9mm. Many thanks for that. Didn't realise that the stripper plates are coated with teflon, very interesting info. I suppose that applies to all mpc's with a stripper plate ? How can you tell if the teflon coating is worn off then ?
                    To the suggestion of setting thick paper settings when printing, this can be rather impractical, such as an internet cafe that has 15 computers connected to the printer, they cannot instruct each customer to print 'thick paper' setting if they print one type and normal if they print another type. They just want to click on the 'print' and collect their print.
                      • 37532
                      Re: Printable area
                      I learned about the stripper plate in a reply debz1964 made to a post on exit jamming a few years ago. If there is any toner build up on the edge of the plate, the coating has worn off.
                      • sturmtrooper
                        Copier Combobulator
                        • May 2016
                        • 587
                        Re: Printable area
                        If they are running thick paper they have to set the machine appropriately or it just wont' fuse toner and toner will start adhering to the fusing sleeve. and other fuser parts. The realities of copier operation don't bend to customer whimsy. There is a point at which they will start getting toner flaking off the paper and ghosting.
                          • 37532
                          Re: Printable area
                          In order for them to be able to just click 'print' and collect their print, then everyone has to put print on the same type and size paper.
