Need reverse order printing
  • mdfurqan2012
    • 194
    Dear all,
    We have ricoh aficio 2090 in client premises who wants reverse order printing of ms access report, means if he sent a job of a document having 10 pages, machine start print page no. 10,9,8,7....1.
    I try to find that option in driver PCL6 but not succeed.
    Kindly guide me.
    I am very thankful to you.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: Need reverse order printing
    You can do this with the RPCS driver. You will need to use Preferences > Add/Change Custom Settings > Misc > Reverse order print > Save As. Give the new option a name, and everytime reverse order printing needs to be used the customer can select the new setting.
    Or under Preferences, set the Printer Configuration to Multi-tab, then re-open the Preferences window. You can select Misc > Reverse order print for a one time use.
      • 37508
      You could try using a PCL 6 driver for a different model such as the MP 9002 or the Pro 907EX. Do not use the PCL driver for Universal Print as it only supports features that are available on all models.
