ricoh 3800c copier not working
  • pepg
    Hello, I have a problem with a ricoh 3800c I do the maintenance on my own copier and yesterday the copier just stop making copies, actually it does make copies but they come out is almost blank, like there was nothing on the original paper. It is working perfect as a printer but not as a copier or scanning machine. Can anyone help me?
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • FRIDGEMAGNET
      • Aug 2007
      • 377
      Have you tried performing an ACC in User tools, Maintenance?
      • pepg
        can you tell me how to do that?
        Thanks,
        • JustManuals
          • Jan 2006
          • 9838
          RTFM !
          • FRIDGEMAGNET
            • Aug 2007
            • 377
            This is an extract from the user manual which you can download from Ricoh USA site.
            • pepg
              I've tried the ACC and did not work, any other ideas
              • pepg
                I have the manual thanks, I have done everything there and is not working!!
                • JustManuals
                  • Jan 2006
                  • 9838
                  Apparently you didn't read the header:
                  'An online community for Copier, Printer & Fax Technicians'
                  Call a technician then.
                  • E Winter
                    Strange - if your scanner would have a problam, you should get an error message if you try an ACC and the machine isn't able to read the chart
                    • FRIDGEMAGNET
                      • Aug 2007
                      • 377
                      This is the point that I must agree - sounds like you need a tech.
                      • pepg
                        I have had a tech check it out and they did not come out with an anwser other than buy a new one. Do you have a better anwser?
                        • Jomama46
                          • 2900
                          I understand you are probably a tech but due to your ad within your posts, you are acting in the capacity of a salesperson. So I dont think you have room to criticize a user asking a question.
                          Calm the heck down dude.
                          sigpic
                          A+; Network +; PDI+
