ricoh mp 2851
  • Transam1
    • May 2011
    • 48
    ricoh mp 2851
    I have a Ricoh mp 2851 with the optional 2 tray paperbank
    have replaced the pick up roller and clutch still occassionally
    says paper jam open side door and remove jam
    when you open door there is no jam it hasn t even picked up
    paper. close the door and off it goes any ideas ?
  • TechnicianWilson
    • Mar 2017
    • 4
    Re: ricoh mp 2851
    clean & check photo eyes for paper dust
      • 37560
      Re: ricoh mp 2851
      Check operation of paper lift. If the paper lift sensor gets activated too soon, as paper is fed, the level of the top sheet can get to the point where the pick up roller is not in contact before the lift sensor has activated to turn the lift motor back on. I have seen this caused by warped lift pan and by there being 5 or more sheets of paper with corners bent under there by lifting the back corner of the paper, where the lift sensor is, higher than the center of the paper where the feed is.
      • Transam1
        • May 2011
        • 48
        Re: ricoh mp 2851
        Thanks I will have a look
