Ricoh MPC4500 blur
  • Hadster
    • Aug 2011
    • 264
    Ricoh MPC4500 blur
    Blur is only on cardstock using by-pass and thick 1.
    Regular 20lbs paper is fine with no blur.
    Replaced fuser and ITB
    Adjusted thick 1 paper buckle for by-passs
    Feeding in Landscape so blur is on trail side (about 3in. from trail)
    Any idea's?
    • 37489
    Re: Ricoh MPC4500 blur
    Blur is happening at the PTR not the fusing unit or ITB. I would say that the trail edge has just left the registration and the only thing driving the last half of the paper is the PTR. If the paper hesitates at the fusing entrance guide, a buckle can form between the PTR and the fusing unit. When the trail edge leaves the registration roller, this buckle is pulled out causing the blur. Check the entrance guide for toner build up. You may also have to adjust the entrance guide.
    • Hadster
      • Aug 2011
      • 264
      I like your thinking slim! I'll give it a shot first thing Monday morning and let you know. Thanks
      • Hadster
        • Aug 2011
        • 264
        Adjusted entrance guide on fuser and all is well! Good call Slim!
        • paulox
          • Jun 2017
          • 3
          I have exactly the same problem. How did you solve it?
            1) thread 2 years old....
            2) re-read the thread.. in FACT you quoted the FIX
