mp cw2200 printing streaks/boxes
  • kudamangalath
    • Jun 2025
    [CQ] mp cw2200 printing streaks/boxes
    hello,
    Any body faced like this types of box or sometimes streaks(black-marked in with red marker) coming ramdomly on the printouts.
    While taking the SMC report also is coming.Cleaned the encoder strip,changed the bearings in the carriage.
    Also changed the black print head.Still its coming the same.No progress.If anybody faced like this issue ,please reply.
    It will be very helpful.
    Thank you
  • mikadonovan
    • May 2008
    • 2931
    Re: mp cw2200 printing streaks/boxes
    From the SM....
    7.11.9 IMAGE ABRADED, PAPER TORN, INK RUNNING
    Output not clean, paper corner bent
     Print head abrasion
     Dog-eared corner of paper
     Ink run
    Gap Adjustment
     Make sure that the gap between the carriage and the platen has been adjusted correctly for
    the type and thickness of the paper.
    Paper Feed Obstruction
     Inspect the platen for paper fragments or dirty plates. Clean the plates.
     Check around the carriage unit for paper fragments.
     Check around the maintenance unit for paper fragments.
    Faulty Carriage Unit
     Replace the carriage unit.
    NEVER ASSUME ANYTHING
