c5502 fax isuue
  • mikadonovan
    • May 2008
    • 2931
    c5502 fax isuue
    thumbnail (1).jpgMorning, All. I have a network error on the Fax on this machine. I have never seen this on the fax. Anyone run into this before?
    NEVER ASSUME ANYTHING
  • mikedci
    • Jul 2010
    • 227
    Re: c5502 fax isuue
    Is fax forwarding set up? Maybee the fax didnt get forwarded...
      Re: c5502 fax isuue
      are they on an analog line or VoIP? I have seen that on a VoIP system... resetting the router took care of it .
      • mikadonovan
        • May 2008
        • 2931
        Re: c5502 fax isuue
        A reboot took care of the issue, although the phone jack plate hanging out of the wall supported only by the wires is not helping the situation.
        • JOLYNAR
          • Nov 2012
          • 44
          Re: c5502 fax isuue
          Go to fax Features Search parameter setting, the change switch 21 bit 6 from 1to 0
          Reboot the Copy machine
          Inviato dal mio RAINBOW JAM 4G utilizzando Tapatalk
          • sandmanmac
            • 3979
            Re: c5502 fax isuue
            Agree!
            The message will probably return. I've seen this 2 or 3 times in my life. No other issues with the machine. All network settings were correct. Message kept returning after a day or 2.
            Turned of "display network errors" as Jolynar said, and it never comes back
