Ricoh mpc3501
  • duplicators
    • Apr 2016
    • 63
    [Dead] Ricoh mpc3501
    Black display show image anY ideas thanks
    Enviado desde mi Moto E (4) mediante Tapatalk
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    Re: Ricoh mpc3501
    Is there any print engine activity / movement on power up?
    If there is try accessing the web interface and seeing if there is any error code displayed.
    If it just sits there with a green light and no engine activity on power up it could be number of things.
    • Missing voltage range / check blown fuse conditions on the PSU.
    • Faulty PSU
    • Faulty controller
    • Faulty polygon mirror motor / BICU
      • 37491
      Re: Ricoh mpc3501
      If you can access WIM, check the status for error codes. SC 202, SC 203 or SC 204 would indicate a blown polygon mirror motor. On some models, the polygon mirror motor will also take out the BICU. Replace both as a set to prevent blowing the new part if you only replace one.
      • duplicators
        • Apr 2016
        • 63
        Re: Ricoh mpc3501
        • Faulty PSU
        • Faulty controller
        No activity
        • Zeldaman
          • Mar 2011
          • 946
          Re: Ricoh mpc3501
          Hi there!
          Take a flashlight in an angle of ca. 45 degrees & look if can see the errorcode on the display. As slimslob mentioned the BICU/polygonmotor you can see the error-code with this trick.
          Greetings...
          • StephenB
            • Aug 2015
            • 243
            Re: Ricoh mpc3501
            Taking a solution from a previous thread...and we used successfully.
            If this is a SC 202 resulting from a bad polygon and the BICU has also failed.
            Take a look at the BICU for a tiny resistor (very tiny) near the lower right power connector. There is a row of them, they all have a "0" printed on them, except for the one which is "burnt"
            If your good with soldering, there were some who have replaced them. I just soldered across the resistor and has been good for quite a while now. ( I did replace the polygon to prevent another failure)
            Figured it would need a new BICU anyway, nothing lost in trying.
