Mpc2003 jamming at exit
  • slot
    • Jul 2008
    • 341
    Im looing for some advice here as we have a very low volume MPc2003 that has for the last few weeks been jamming with code 20 and 24.
    The paper is just coming out of the fuser it will only once in a blue moon do this so the engineer has only seen it once.
    We have changed the complete fuser and all the fuser exit senor and the inverter senor and the sensor on the transfer unit we have also tried a new transfer belt unit
    We can seem to get on top of this we have also change the inverter gate and solenoid and of course upgraded the firmware.
    All of this and we still have a problem can anyone shine any light on this problem thanks.
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: Mpc2003 jamming at exit
    is machine standing in a normal environement?
    Does the paper stay for a long period in the paper tray?
    Is the problem the same with a new paper out of the box?
    Is it solved with a tray heater?
    Are the paper guides in the paper tray at a position they should be?
    • slot
      • Jul 2008
      • 341
      Thanks for your reply we have given them fresh paper to try after it jams which didnt improve it and all the guides are in the correct positions and we have changed the feed in one tray its very odd.
      • Mark Bbb
        • Jun 2012
        • 1662
        paper isn't wrapped, so it is a matter of electronic failure.
        Put the paper size in all trays to a fixed one, solved?
        Moisture can build up at sensors, fan broke (but then a code would come up)?
        • sharpmind
          • Sep 2009
          • 478
          I have encountered that problem. See if the duplex unit is broken or not. Make sure that part is aligned properly otherwise paper will jam.Capture.JPG
          • slot
            • Jul 2008
            • 341
            thanks for all you help we will try the dplex unit
            • denesh
              • Mar 2011
              • 9
              Does the machine have a one bin tray and have you installed the gear that comes with the one bin tray unit ?
              • apump
                • Mar 2009
                • 160
                look at he jam codes and see if you have a lot of power on jams. J001. if you do replace the right side door.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Solved?
                  • copywhisperer
                    • 8
                    I had exact same issue yesterday & fixed it today. As Sharpmind said, the broken Duplex entrance guide was the cause. the M/C started working as soon as the guide was replaced. the catch on the rear side of the assembly was broken & the entire assembly was out of home position.
