MPc3002 Scan to Email with Gmail
  • tufbnme
    • 493
    I know this has been done to death but I have not found a suitable answer.
    I installed a MPC3002 the customer wants to scan to email with their Gmail account. They currently have an older Ricoh that scans to their local machine and it relays it SSL.
    I use all the same outgoing settings as the relay machine:
    SSL authentication, port 465,
    DNS 8.8.8.8 OR 8.8.4.4,
    Server name:smtp.gmail.com
    password is correct, I can log into their gmail account with it
    No domain used just workgroup
    Static IP address,
    What am I missing?
  • sandmanmac
    • 3979
    Re: MPc3002 Scan to Email with Gmail
    Setting the port to 465 in WIM isn't enough, You still have to enable "use secure connection (SSL)" on the machine itself or scans will fail.
    UT/ System settings/ FIle transfer/ SMTP Server/ Use secure connection / ON
    • tufbnme
      • 493
      Forgot to mention, It is enabled
      • sandmanmac
        • 3979
        Is it an Authentication Error?
        If so, then they probably have 2-step verification enabled on the account, so you'll have to generate an App password to use rather than their regular account password
        • tufbnme
          • 493
          The 2 step verification is off
          • tufbnme
            • 493
            Really not sure why but it started working. I did not change any settings. I had logged into the gmail account and was checking settings (didn't change any) and went back and tested the machine...worked! I don't get it. I have set many of the up and always the same way, 95% of the time they work.
            • SargeNZ
              • May 2012
              • 263
              Sometimes I have to log into the account on a local computer, Gmail will often then provide an alert about a blocked login attempt. Often after resolving this it seems to work. I have also seen cases where it can take 48 hours for things to start working, even after OKing the device.
              • zed255
                How'd ya manage that?
                • 1024
                Ensure that the gmail account allows 'less secure applications'. Set that in the security preferences of the gmail account.
                  • 37365
                  Currently smtp.gmail.com requires SSL/TLS not just SSL. The local relay will provide this. The MP C3002 does not. You may want to read the following link to Google support document on setting up scan from a printer, scanner, or app.
                  Send email from a printer, scanner, or app - G Suite Administrator Help
                  You also may need to modify the security on the gmail used as sender.
                  Let less secure apps use your account - Google Account Help
                  • tufbnme
                    • 493
                    Google states that it can be either SSL or TLS. It does not state only TLS. I have it working with a C4503, port 465 SSL only
                    • ruben
                      The New Guy
                      • Oct 2012
                      • 1203
                      I had a 3002 recently stop working with Gmail, updated the network firmware cured it.
                      • tufbnme
                        • 493
                        Thanks, all the FW is up to date.
                        • tufbnme
                          • 493
                          Re: MPc3002 Scan to Email with Gmail SOLVED
                          Went back to customer today and the machine would not connect to server. Finally found that the customer had changed the default gateway on his router and didn't bother to mention it. Set the gateway and...boom works.
                          Merry Christmas
                          • nwerle
                            • Sep 2019
                            • 3
                            danger - so how can is set more secure and still work?
                            do I need a current certificate if using SSL?
                            • sandmanmac
                              • 3979
                              As stated in my 2nd reply in this thread nearly 2 years ago, create an app password in your Gmail security settings, and use that for authenticating the machine. If that doesn't work, a F/W update on the machine may be necessary. Consider yourself warned NOT to ask for the F/W here.
