mp2851 jams at power on
  • Mark Bbb
    • Jun 2012
    • 1662
    Have already replaced:
    1. bridge unit switch
    2. switch at the right rear side of the main frame (somewhere knee-high).
    3. front- and rightdoor switches (3 pieces) at the front side of the main frame.
    Still getting jams at p.o. once every 1K print...
    Anyone?
  • Zeldaman
    • Mar 2011
    • 946
      • 37377
      Re: mp2851 jams at power on
      You said that you replaced the bridge unit switch. Does that mean that you replaced one switch or did you replace both?
        what jam code is it kicking?
          • 37377
          Jams at power on are always J001. When they happen during operation it is because the machine thought a door was opened and closed.
          • Mark Bbb
            • Jun 2012
            • 1662
            Slim: Both?????
            I cheque my manual...
            • Mark Bbb
              • Jun 2012
              • 1662
              Slim: my manual only mention one switch, G020 5626 Push Switch 7 - 19
              Perhaps you are refering to AW02 0180 Paper Feed Sensor 7 - 23 ???
              Could this one be the issue?
                • 37377
                Only one part number. Used in 2 locations. One for each cover that can be opened to remove jams.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Slim: You rock!
                    • 37377
                    Slim: You rock!
                    No. I've just had to replace a few.
