Ricoh MPC 2503
  • dave w
    • Jun 2015
    • 230
    [Misc] Ricoh MPC 2503
    Please can somebody advise?
    I have a issue with a MPC2503 where the colour alignment is slightly off, please see attached pic.
    this was spotted atter a dev & pcu assy was fitted.
    On investigation it seems old print outs whichare building plans have the same issue but not been spotted before.
    whats been done
    ACC - Force Line adj - fimeware updated Engine-Sys/copy-network support.
    advised used to update the driver via the IT dept. I have been told that the driver has been updated.
    Any advice please as need to know if its the copier?
    Thanks in advance
    Dave
    Re: Ricoh MPC 2503
    whats been done
    Thanks in advance
    Dave
    you need to get an 8x jewelers look and do a manual line adjust... PIA.. did the Forced Adj kick any errors?
      • 37495
      Re: Ricoh MPC 2503
      Did you clean the ID sensor assembly before running forced line adjustment? I have had times when just cleaning th e sensor pulled the colors back into alignment.
      In the past, Ricoh has had some problems with slippage of the ITB causing alignment to fail after a few copies. If you have another machine available try swapping the ITB units.
      I had one instant where at the back end of the shaft that the right hand ITB unit release lever there is a latch that had broken. Since it holds that end in position, it caused the unit to move forward slightly when the shutter solenoid for t he ID sensor engaged. This threw the adjustment off.
      • dave w
        • Jun 2015
        • 230
        Re: Ricoh MPC 2503
        Hi Phil
        first time I got a 1 then after running it a few more times I got a 0 both times
        many thanks
        • dave w
          • Jun 2015
          • 230
          Re: Ricoh MPC 2503
          Hi Slimslob
          Yes i was thinking on a possible ITB issue. to be honest no i didnt clean the ID sensor, Will be visiting back to investigate further so will start from scratch and to that first.
          many thanks
          • Ricohguy
            • Sep 2012
            • 48
            Re: Ricoh MPC 2503
            I'd also agree it is probably an ITB issue. Check the tension roller, I had similar issues when a tech didn't tighten one of the screws all the way.
            • dave w
              • Jun 2015
              • 230
              Re: Ricoh MPC 2503
              BIG thanks to all
              Yes it was the ITB - I even tried the suspected belt back at our workshop and BOOM! same issue.
              Thanks to all again
              Dave
