mpc5503 faint shadow only on 280gms card
  • Elmo
    • Feb 2010
    • 541
    Hi all
    Customer has MPC5503 total use 260k BLK 40k Col
    This only happens when customer is printing onto 280gsm card (silk finish) (use 250gsm no problem)
    it is producing a shadow line very faint about 2mm wide in the non feed direction
    it is about 750mm from the lead edge same place every time happens on both landscape and portrait, same using bypass or paper tray
    it looks like as the lead edge of the card hits the fuser unit it causes a slight buckle and contacts the transfer belt
    there is no image distortion just a faint line appears
    iam thinking its a speed issue between paper drive, transfer and fuser
    fuser was new 2 months ago due to sleeve surface damage, transfer belt has done 300k
    all other printing is ok good quality only happens when using the 280gsm i have told customer to use 250gsm
    but would like to see if i can fix it or at-least find out what is causing it
    (line is just visible but will not show up on scan so i can post sample)
    I Used To Live To Fix Things Now i Fix Things To Live
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: mpc5503 faint shadow only on 280gms card
    Unfortunately this is a known fault on the Metis. It does it on both the 03 and 04 models and there is no cure.
    Hit it.
    • Zeldaman
      • Mar 2011
      • 946
      Hi there!
      What is the counter of the itb-cleaning-unit? Maybe the cleaning-blade is worn out.
      Greetings...
      • Elmo
        • Feb 2010
        • 541
        Cleaning unit is still the original 300k
        but it is only getting the problem on the 280gsm
        customer seems happy to use 250gsm with no problems
        • Elmo
          • Feb 2010
          • 541
          Thanks Toner Munkeh
          Save me time looking into things further to try and fix it
          • Mark Bbb
            • Jun 2012
            • 1662
            Despite Tonermunkeh's reply, have you update the firmware? Perhaps there is a solution now?
            • Elmo
              • Feb 2010
              • 541
              Thats on my to do list for Monday
              ive look for any tech bulletins on it but didn't find any
                • 37491
                Since it is at the same distance from the lead edge and only with silk finish 280gms paper, I would check for the lead edge hanging momentarily entering a set of rollers. A fusing entrance guide with toner build up can be the cause.
                • Elmo
                  • Feb 2010
                  • 541
                  The fuser unit is only a few months old i checked the entrance guide it was clean
                  got customer to try a 280gsm plain card the line is barley noticeable but is still there
                  it would seem to be on any card 280gsm and above
                  it would def seem to be delayed but there is no noticeable defect in the image in the same area
                  • BLADE
                    former propeller tester
                    • 478
                    so if you place the sample fault line at the ITB or fuser where does the L/E line up (750mm is a long way - almost a metre !)
                      • 37491
                      I am assuming that he has that number wrong. Maximum imageable size is 316X432mm. Maximum paper size for paper trays 2,3 and 4 is 297X420mm, tray 1 is 297X210mm.
                      • Elmo
                        • Feb 2010
                        • 541
                        Yes that should have read 75mm from lead edge
                        as the lead edge hits the fuser the shadow lines up with the itb
                          • 37491
                          If the fusing unit has an adjustable entrance guide, try adjusting it.
                          • moonraker
                            • 28
                            Yup, I had this issue with 300g cardstock and a faint band at 75mm two years ago on a 3003.
                            Despite the efforts of many it was never resolved. 250g card and below was fine.
                            The 75mm is the length between the nip and the ITB/PTR points
                            • Elmo
                              • Feb 2010
                              • 541
                              i have had chance to test 3 different machines 2 x mpc4503 1 x mpc5503 all with 280gsm and 250gsm card
                              all produce the shadow line in the same place some slightly more visible than other
                              before testing updated all machines to latest firmware, fuser and itb condition good in all machines
                              iam going to look through the adjustments to see if i can make any difference
                              but it would seem that this is an issue with the 03 range
                              anyone had this or have any advise
