Ricoh MPC 2051
  • muhammadreza
    Lerner
    • Aug 2012
    • 39
    Ricoh MPC 2051
    I have a machine in customer place . that machine have problem please wait i solve that problem change BICU board .After change board machine working but cyan color are not good i put sample print . BICU bord is new . I change cyan drum unite, change high voltage board same problem can anyone tell me what is the problem.
    • 37510
    Re: Ricoh MPC 2051
    Did you change just the drum unit or the PCDU, drum unit and development unit?
    If the paper was fed SEF, Short Edge First, you might have a problem with the Cyan transfer roller in the ITB assembly.
    • copier tech
      • 8164
      Re: Ricoh MPC 2051
      Before you replaced the BICU was the cyan quality OK? (prior to the please wait fault)
      • muhammadreza
        Lerner
        • Aug 2012
        • 39
        Re: Ricoh MPC 2051
        I change drum unite and devloper unite. but i didn't change ITB assembly thanks to replay
        • muhammadreza
          Lerner
          • Aug 2012
          • 39
          Re: Ricoh MPC 2051
          customer tell me it was ok before but i have doubt because machine was dead.
