MPC4504 - Not recovering from SLEEP mode
  • Batman1976
    • Jun 2016
    • 91
    Hi Fellow Tech's,
    I have a strange fault on a Ricoh Mpc4504SP - When a print job is sent to the device when in sleep mode the machine does not recover (locks up). Screen remains black with blue light on but no print is ejected, touching the screen also does not work. Even the main power switch on does not respond so the only way to reset the device is to physically unplug it. Other functions work fine i.e COPY, SCAN. The client has 2 devices, the other machine works fine.
    I have updated all firmware levels on the device and Cheetah Op Panel - Still happens. A Controller has been ordered.
    Has anyone seen this and got a fix? Or does anyone know if you can switch sleep mode OFF!!?
    Cheers
    Batman76
  • Gift
    • Mar 2011
    • 2459
    Re: MPC4504 - Not recovering from SLEEP mode
    Try a local test with your notebook and cross over cable.
    • Mark Bbb
      • Jun 2012
      • 1662
      The machine stays in sleep mode when it receives a print.
      To wake it up, lift the ADF or put an original in the ADF input table.
      • Besserwisser
        • 25
        Hi
        Have had this same problem, but on mpc 4503 basicly the same machine. 2 times ended up changing the controller and one time the power supply...
        Hope the controller works for you.
        • Mark Bbb
          • Jun 2012
          • 1662
          [QUOTE=Batman1976;587749]Hi Fellow Tech's,
          Actually, you mean when sending a print job, it doesn't print ...
          i didn't understand it that way.
          Might be my accent...
          Oh
          • copier tech
            • 8191
            I had this exact same issue on a few MPC305's once they went into sleep mode the control panel power button or sending a print job would not wake them up, pull the power & back in fine again.
            This issue was a little intermittent however I used SP5-191 this basically stops the controller from going to sleep, the panel & rest of the machine fall silent so it appears the machine is at sleep as normal.
            Used this setting a few times works every time not sure if this SP is the same on the MPCxx04 series worth a try.
            • Gary Bowen
              Bowdog
              • Mar 2008
              • 250
              These are some of the solutions for other Ricoh MFP's and should work for the "04" series:
              1. Set SP 5191 to "0" to Disable Sleep Mode.
              2. If FAX is installed, in FAX Mode set Bits 1, 4 and 5 in SP 1101-022 to "1".
              3. If Extended Features are not being used JAVA can be disabled with SP 5730-001 ("0" to Disable).
              Hope this helps and saves you the cost of a Controller PCB.
              • Besserwisser
                • 25
                SP5-191 have not help me but it doesent cost to try
                • Batman1976
                  • Jun 2016
                  • 91
                  ** UPDATE**
                  Thanks for the input guys, the controller was fitted and cured the Sleep/print issue and sent back on warranty.
                  However, the device has a further fault where the Document feeder will intermittently throw a double sided original straight out without inverting the 2nd side showing a paper jam at P. ADF firmware has been updated, any one had this before? (The Feeder model is a DF3090).
                  Cheers
                  Batman1976
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    Originally posted by Batman1976
                    ** UPDATE**
                    Cheers
                    Batman1976
                    Bloody DF3090......
                    There are two optical sensors that collect dust faster than my ex collects child support.
                    It will tell you that you have a jam in the duplex or another symptom is a phantom jam when you lift the adf lid.
                    Strip out the black feed plate and clean the optical sensors.
                    • Zaxxon
                      • 608
                      I have this problem too, every morning.... could someone please update my fw
                      Please start you post with brand, model, problem.
                      • Lagonda
                        • Aug 2008
                        • 1649
                        Originally posted by Oze
                        Bloody DF3090......
                        There are two optical sensors that collect dust faster than my ex collects child support..........
                        Thanks Oze, thats the best laugh I've had so far this year.
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          In fact, we could open a forum such as "copytechnet.com" but than espacially for maried men "marriedmen.com" or so...
                          It could look like this:
                          Well, my wife always cracks one off when meeting new friends and not in a silent way, no...
                          Anyone have seen this trouble before?
                          OR
                          Oh, my wife has gone fishing with my best friend, but her fishline is still here, and it's almost dark.
                          What could possibly go wrong?
                          • Kevinong
                            • Sep 2024
                            • 4
                            Hi everyone. I m Kevin. I m new member here. I oso hv this problem. Machine go to sleep mode then display going black can't function at all. Does everybody know what the problem. Is it firmware or controller problem.
                              • 37555
                              Go away grave robber.
