Ricoh mp2550b
  • kopirmaster
    • Apr 2011
    • 70
    Ricoh mp2550b
    hello
    I have problem with ricoh mp 2550b printing with rpcs driver .
    whan you print from office ,pdf or something else everything is ok,but whan you try to print from web browser machine doesent accept the jоb.
    Does someone encountered this problem .
    thanks for your time .
    encounteredencountered such a problemencountered such a problemencountered such a problem
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh mp2550b
    Why are you using RPCS? Get a config page off the machine and check the "supported languages" bit, what does it say there?
    Hit it.
    • kopirmaster
      • Apr 2011
      • 70
      Re: Ricoh mp2550b
      this machine support only rpcs driver (mp2550badr) .
      • guitar9199
        • Sep 2016
        • 1100
        Re: Ricoh mp2550b
        Try using the PCL drivers for that machine. The 2550 has PCL installed native.
        • kopirmaster
          • Apr 2011
          • 70
          Re: Ricoh mp2550b
          whan i instal pcl driver the job come to the machine and machine deleted by her self .
            • 37508
            Re: Ricoh mp2550b
            The MP 2550B, the B is for basic, came with no native print function and B/W only scanning. Apparently the salesman tried to save a few bucks on cost and only added the RPSC Printer Unit Type 3350, EDP code 414402, instead of the Printer Scanner Unit Type 3350, EDP code 414401. The solution is to add the Printer Enhance Option Type 3350, EDP code 414114. This will add PCL support.
            • kopirmaster
              • Apr 2011
              • 70
              Re: Ricoh mp2550b
              thanks a lot man !
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                Re: Ricoh mp2550b
                To add on, essentially ALL support has been stopped on RPCS, and redirected to PCL6.
                Im surprised it even works at all at this point.
                  • 37508
                  Re: Ricoh mp2550b
                  Over eight years ago.
                  Ricoh abadon’s its RPCS print driver | MFPs, MFDs, PRINTERs & COPIERs
