Mp161 continued
  • tcypy1961
    • 773
    Mp161 continued
    I went back out to the copier to replace the PCU for offsetting problem I initially thought was fuser related. Once installed an SC322 came up. I put old PCU back in copier & the code remained. I cleaned the BICU & the code remained. I then put the toner cartridge back in and code went away. I removed cartridge and the code was still gone. I installed new PCU code still gone and offsetting problem the Copier had is gone. Should I not look a "gift horse in the mouth" or should I be concerned about the SC322??? Replace the BICU??? Copier is working at this time.
    Thanks!!!
    Re: Mp161 continued
    Thanks!!!
    that is a issue we have all faced from time to time... it's working do I want to screw with it more? Will is come back?
    all depends on how upset has the customer been during this ordeal. Did you make it known to them about the issue and " Please keep an eye on it.. but I have not gotten it to replicate the problem."
      • 37533
      Re: Mp161 continued
      The code means No Toner Cartridge installed. This model has a lever at the back of the toner cartridge tray that deactivates the laser when there is no toner cartridge in the machine.
      • bob marley
        • Jan 2012
        • 1339
        Re: Mp161 continued
        agree with u slimslob , this code comes if toner bottle is not installed
        Live for yourself and you will live in vain. Live for others, and you will live again
        • kopirmaster
          • Apr 2011
          • 70
          Re: Mp161 continued
          not toner bottle,toner suply is not instaled .if is instaled check the laset unit.
            Re: Mp161 continued
            i
            isn't that the same thing?
            • guitar9199
              • Sep 2016
              • 1100
              Re: Mp161 continued
              i
              Not necessarily. The Toner BOTTLE sits on the Hopper (Supply) unit. I've seen machines with no bottle, but the hopper is installed, that would run, but if the HOPPER isn't installed, I've gotten the 322 code as well.
              ...but yeah, if both are installed, I'd lean toward laser unit.
                • 37533
                Re: Mp161 continued
                i
                I believe that with this model the shutter is actuated by the bottle. In order to be positioned properly to actuate the shutter, the bottle need to be in the toner tray.
                • bob marley
                  • Jan 2012
                  • 1339
                  Re: Mp161 continued
                  Toner bottle not installed
