Pulse/tone dial
  • mrwho
    Major Asshole!
    • 4299
    Pulse/tone dial
    Good afternoon!
    Could someone please enlighten me on how to select pulse dialing or tone dialing in Ricoh mfp with fax option, for troubleshooting? I can't find it anywhere, and it's driving me crazy...
    Cheers!
    Mascan42
    Ibid
  • mikadonovan
    • May 2008
    • 2931
    Re: Pulse/tone dial
    On a c5503...User tools>facsimile features>initial settings>select dial/push phone.
    NEVER ASSUME ANYTHING
    • mrwho
      Major Asshole!
      • 4299
      Re: Pulse/tone dial
      Thank you. On this specific case, it's on a mp171, so I'll check it ASAP and give you some feedback.
      Thanks!
      Mascan42
      Ibid
      • mrwho
        Major Asshole!
        • 4299
        Re: Pulse/tone dial
        No dice. I've already had been looking everywhere before and now double checked where you said and there's no such thing. Even on fax sp there are several settings that mention pulse duslibg, but no option whatsoever to select between pulse and tone.
        Mascan42
        Ibid
          • 37508
          Re: Pulse/tone dial
          Thanks!
          Help us help you by providing the model designation in your original post.
            • 37508
            Re: Pulse/tone dial
            It is User Tools - Fax Function - Administrator Tools.
            Select Dial/Push Phone
            Use this function to select a line type.
            Dial and Push lines are available for selection.
            This function is not available in some areas.
            1. Select [Fax Features] using [] or [], and then press the [OK] key.
            2. Select [Administrator Tools] using [] or [], and then press the [OK] key.
            3. Select [Select Dial/Push Phone] using [] or [], and then press the [OK] key.
            4. Select [Push Phone] or [Dial Phone (10PPS)] using [] or [], and then press the [OK] key.
            5. Press the [User Tools/Counter] key.
            • mrwho
              Major Asshole!
              • 4299
              Re: Pulse/tone dial
              The reason I didn't was because I really thought (naive, perhaps) that it would be (at least approximately) the same for most MFPs.
              That probably is it. I need to try it by choosing some other options on the Area selection!
              Will do it sometime next year - thank you very much! Will keep you posted!
              Cheers!
              Mascan42
              Ibid
