problem twine ricoh mp 2000
  • tullio
    • Feb 2012
    • 268
    how do I edit the scnhost file? urgent, thank you
    • 37533
    Re: problem twine ricoh mp 2000
    If you are trying to use TWAIN scanning and have installed the TWAIN driver, read this thread. http://www.copytechnet.com/forums/ri...61=#post116131. Be aware, the software you are using must be TWAIN compatible and must be a 32 bit software.
    If you are not using the TWAIN driver, the SCNHOST file will not help you.
