Converting any ricoh mpc into black only copier
+ More Options
Posts
  • vga_man
    • 78
    Hello everybody!
    Have anyone tried to convert ricoh color copier into a black only device and remove all color pcu ?
    I just saw this copier today, so decided to start this discussion with you...
    Any ideas? ๐Ÿ’ก
    Re: Converting any ricoh mpc into black only copier
    removing the PCU's will keep the machine in an error state..
    you need to set print drivers to black only .. and set walk up control to black only
    do NOT remove components from inside the copier.
    • tufbnme
      • 493
      Just get a black only machine, why go through the trouble? They are cheaper too.
      • david0161
        • Nov 2016
        • 14
        Enable user codes to restrict all color printing and copying. If you try to print in color the machine simply will kill the job, copying would require code but you don't even have to set one up.
        • fshead
          • 2378
          OR you can swap out all color developer for black////////////
          i never get these kind of question without model machine and a WHY?
          • vga_man
            • 78
            Model mpc4000
            Reason : because color toner so expensive here and most toner bottels aren't genuine so pumps doesn't work... Every restart loading toner seems...
            I saw copier works without color pcus...
            Can i disable loading toner every job?
            Thanks for respect ๐ŸŒน
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              Originally posted by vga_man
              Model mpc4000
              The machine does not load toner every job, only when needed. It does do process control periodically, which can be disabled, but that will usually cause you copy quality issues in the long run. No it cannot be disabled for just color. The machine is designed to work as a whole.
              It will not work without the color PCUs inside it. Even if you managed to get it to try to run it would lock up at the first process control.
              For when you really need it to be black, now with four times the black!
              • fshead
                • 2378
                i was being sarcastic and i agree if you are not making color copies you will not be adding color toners.
