Ricoh 4000 Blank screen
  • kayjaig
    • 144
    [Dead] Ricoh 4000 Blank screen
    Hi, I am working on Ricoh MPC4000. It shows blank screen with power lights on.I have replaced good panel and control unit. It remain the same. Any ideas. Thanks.
  • vga_man
    • 78
    Re: Ricoh 4000 Blank screen
    Happend with me, replaced BICU board, and laser polygon motor..
    BUT you may first test fuses Area on Power board
      • 37489
      Be sure to replace booth at the same time. The blank panel is caused by a blown BICU. The BICU is blown because of the polygon motor. If you only replace the BICU, the bad polygon motor will blow the new BICU.
      • kayjaig
        • 144
        Cools. Thank you for all advices.
        So replace both BICU and Laser unit at the same time is the key.
