MP301spf firmware not loading
  • Hadster
    • Aug 2011
    • 264
    Trying to load firmware like I have done dozens and dozens of times but having no luck. Loaded firmware on the SD card installed in slot 2 and firmware shows up on screen like normal. Touch ROM file to be loaded and hit update and nothing happens! Tried different SD card (have seen SD card cause this before on diff model) but no luck! Any ideas?
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    Re: MP301spf firmware not loading
    Maybe try the old firmware reset :Firmware reset - All Clear > "1" > "4" > "3" > Stop x 3 times .
    Do this with the card in and then reboot.
    Worth a shot I guess.
    • Hadster
      • Aug 2011
      • 264
      Are you suggesting 5801-1!? I don't think so!
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Ricoh calls it "firmware reset"...or at least they USED to.
        If I had been suggesting an "SP5-801-001- Clear All" I'd have posted that up.
        You used to do the Firmware reset for firmware updates that failed...or gave you an E-49 of some other E codes.
        If you don't want to try that you could try:
        Enter service mode SP5-886-001 Permit ROM Update and change the value from "0" to "1". Then reload firmware again to resolve problem.
        OR you could try SP5-801-003 (SCS Memory Clear) and try the update again?
          • 37533
          I have seen this with corrupted downloaded firmware. Try downloading again. Then reformat the SD card using the Panasonic SD card format utility. Windows format does not always produce a usable SD card. This is the link on TSRCricoh-usa. SD/SDHC/SDXC Memory Card Download | SD Memory Card | Digital AV | Support | Panasonic Global
          Minitools Partition wizard also works. It also allows you to create a smaller partition on a card if you cannot get one small enough to work with older machines. Best Free Partition Manager for Windows | MiniTool Partition Free
          • Hadster
            • Aug 2011
            • 264
            Update= reformatted sd card and all is well! I use it so much I guess it should be done more often.
            • copier tech
              • 8174
              How long did you wait? sometimes these little 301's take ages to become 'ready'
              Try again as suggested above but also give it time after the initial ROM screen displays.
              Also you could try the remote FW via the WIM just do the engine & system then try your SD card again.
