SPC 830 Factory Mode
  • AUWI
    • Jan 2018
    • 7
    [Misc] SPC 830 Factory Mode
    Hello
    can someone tell me how I come with an SPC830 in the factory mode.
    Should make after replacing the HHD SP 5-846-046 but there is not in the technician menu
    Thanks for any answer
    Yellow 143 than c and c hold
    do not go here
  • copier tech
    • 8144
    Re: SPC 830 Factory Mode
    You do not need to format the HDD after replacing.
    Simply fit the new drive, power on the machine & it will pop up a message asking "do you want to format the HDD" simply choose yes.
      • 37489
      3.2 ENTERING SP MODES
      If The Power is Already On:If The Power is Already Off:
      Press the "Home" and "Suspend" keys at the same time while turning the main switch on.
      BTW SP5846-046 has nothing to do with HDD format and is only needed when both the Admin and Supervisor passwords have been changed.
      • AUWI
        • Jan 2018
        • 7
        Thx
