c2050 scan to folder
  • LNorris
    • Sep 2008
    • 645
    will a c2050 scan to win 10?
  • sandmanmac
    • 3981
    Re: c2050 scan to folder
    Sure...with proper F/W update - same is true for any MP series, or just setup FTP (no F/W update necessary)
    • LNorris
      • Sep 2008
      • 645
      two of us fought a 10 today. will doublecheck the f/w. thanks, just wanted to make sure.
      • sandmanmac
        • 3981
        Not that I have access to the updates myself, I just know it to be true.
        I know some of the oldest MP series required a "custom" network F/W rather than just the routine update, which may be the case here, so it may be in a different location on the website
          • 37533
          You also need to have the network interface settings on the C2050 correct.
          1. Use target computer netbios name not IP address. Netbios resolution must be enabled.
          2. If it is on a domain, the domain name must be exactly correct and the first DNS server must be the domain DNS, usually the server.
          3. If it is on a domain, the workgroup name must be correct and all computers must also be the same on all computers. The first DNS needs to be a local DNS such as a router.
          This is what I have done with all my school installations and have only had a problem when one of the above was not correct. Normally a spelling error on either the domain name of workgroup name.
          • sturmtrooper
            Copier Combobulator
            • May 2016
            • 587
            The problem with FTP is getting customer permission to install the FTP software, which they will then expect you to support for life.
            Bonus points for having customer that are totally network and computer illiterate that seemingly have no IT department.
              • 37533
              And they don't expect you to support the C2050 for life?
