can i limit a machine output volume
  • aviso66
    • Dec 2012
    • 202
    Can I limit a copier machine output volume per month? lets say 100,0000 copies/printing per month....
    Or can i program it into an extended java card?
    • 23009
    Re: can i limit a machine output volume
    You mean like Department Codes? Where are you slim? =^..^=
    • aviso66
      • Dec 2012
      • 202
      It's something like limiting a machine to only able to perform (print + copies) up to 100,000 unit per month. then it will maybe have errors or notification says limit reached. Afterthat next month it will recycle again.
        • 23009
        Department Codes can do this. Just set up a single department code and limit the number of copies. I assume that your enduser is not allowed to make changes, so you'll have to change the admin password. Monthly you'd have to clear the department code counts. If you are having difficulty with the operators manual, maybe slim can give you a click by click description. =^..^=
        • aviso66
          • Dec 2012
          • 202
          Is it the same as setting user code per user? I checked that it only limits up to 200 copies....
            • 23009
            Sorry, I don't have the operators manual so I can't provide details. I can't believe Ricoh would limit you to 200 copies per cycle. Many of my customers do that in the first 5 minutes. =^..^=
            • aviso66
              • Dec 2012
              • 202
              actually its 200 unit per user
              i cant find the if its able to make it per cycle
                • 23009
                It might help to know what model you're referring to.
                1) Go to Google
                2) type in your model and "operators manual"
                3) press Enter
                4) read
                  • 37529
                  That up to 200 unit setting should always remain set as 1. It is a weighting factor. It can be used in the following manor:
                  1. you have two user. User 1 and User 2
                  2. You want to charge user 1 $0.15 per copy made and user 2 $0.35.
                  3. Set the unit count for user 1 at 15 and user 2 at 35.
                  What you want to use is print volume limits. Depending on the model of the MFP, this may have to be enabled in user tool - system settings - administer tools. Older models that do not support this will require Java be install and the User Account Limit v1.1 setup.
                  'User Account Limits Application' for Ricoh copiers...
