ricoh mpc 2550 unfinished job exists
  • duplicators
    • Apr 2016
    • 63
  • duplicators
    • Apr 2016
    • 63
    Re: ricoh mpc 2550 unfinished job exists
    [QUOTE = duplicators; 591212] Hola, tengo este problema,
    exists job unfinished when i used. when use adf dont work thanks.
    Enviado desde mi Moto E (4) mediante Tapatalk [/ QUOTE]
    • davel
      • Oct 2011
      • 1103
      Press stop button to stop the previous job, check that there is not a previous scan job waiting.
        • 37483
        • ridgemill
          • Sep 2017
          • 190
          The C2550 DF uses a photo interrupt sensor and flag arm, at the rear, to detect the original.
          The sensor could be faulty or dirty, a quick test is to turn on the panel sounds, and place an original in the DF, if it beeps, then the sensor is good.
          • duplicators
            • Apr 2016
            • 63
            I test whit another adjunto,same problem
            • duplicators
              • Apr 2016
              • 63
              I try with another df
