Lanier LD140CSR can't find replacement Drum and Dev assy's...
  • Foo
    • Nov 2009
    • 199
    I've spent a few hours researching a new customers supply items and can't find Drums and Developers.
    Their current machine is in need of a black developer and drum replacement.
    Just picked these folks up as a new customer and now can't find these OEM parts for sale.
    I can see this is a somewhat odd duck as far as Lanier goes.
    Called PR and talked to tech support about using the Ricoh equivalent and they said probably shouldn't just in case there's a different pinout or
    connector issue.
    Any help would be appreciated.
    Jeff in STL
  • fshead
    • 2376
    Re: Lanier LD140CSR can't find replacement Drum and Dev assy's...
    connector issue.
    Jeff in STL
    I JUST picked up a few more of these and if the pm counters are correct they run well over 60k.
    as for difference between ricoh/savin/lanier i would have to ck as i have only seen ricohs and savins..
    the engines are the same but might have a plastic tab to break off or something
    • Foo
      • Nov 2009
      • 199
      Let me know what you find out.
      Not having any luck finding the Drum or Dev. assy.
      There's quite a few other parts available just not these 2.
      Weird
      Jeff in STL
        • 37488
        connector issue.
        Jeff in STL
        That is because they are not supply items. They are parts and can be found in the parts catalog.
        • fshead
          • 2376
          i think he wants to know did tricky rico rico change things up on the lanier drums vs the ricoh mpc300/400 series..
          like they use to do with toners etc etc.
          • fshead
            • 2376
            • FrohnB
              • Jul 2017
              • 1919
              M0262015 = Color PCU
              M0262024 = Black PCU
              M0263034 = Black Dev. unit
              M0263022 = Cyan Dev. unit
              M0263023 = Magenta Dev. unit
              M0263037 = Yellow Dev. unit
              Omertà
                • 37488
                Nice try but it looks to me like the parts catalog is the same. The older differences had to do with the fact that Savin, Gestetner and Lanier were either independent distributors of Ricoh products or partially owned subsidiaries and not wholly owned subsidiaries. In fact if you go back far enough, they even made certain parts different such as the toner bottle holder on the Aficio 551/700.
                • tufbnme
                  • 493
                  Maybe invest in a parts catalog, simple to locate.
                  M0262024
                  PCU:BK:NA:NEW:ASS'Y
                  M0263034
                  DEVELOPMENT UNIT:SUPPLY:BK:NA
                  • fshead
                    • 2376
                    ok as a tech doing thus over 35 years some of us dont have the deluge of manuals and information that those who stay with the "mother ship".
                    We scrap and scrape to keep machines up and still make a living.If i can take a part from a different machine and use it I DO..
                    sometimes i wish i never left the big company but i am not one to play "politics" nor kiss ass so i went solo...
                    it has its goods and it bad too.
                    • Foo
                      • Nov 2009
                      • 199
                      I appreciate the constructive help here...
                      That being said, I have a service and a parts manual for a MP C300 and know this is the crossover model.
                      I also have been in this business 18 years. And remember having toner bottle / toner hopper fitment between Lanier, Savin, Gestetner and Ricoh.
                      Drum cartridge issues between Xerox and it's cross over Sharp models.
                      Manufactures love doing this brand specific part stuff: Ford and Lincoln, Buick and Pontiac, Lifelike and Walthers(LOL model train stuff).
                      I was told not to buy these 2 items (Blk Drum and Dev) per tech support at PR.
                      Why you ask...possible part fitment issues between Lanier LD 140csr and its crossover Ricoh MP C300.
                      So I came to you folks with a more hands-on knowledge of the issue and hopefully better answers.
                      So without all the extra does someone know if these 2 items:
                      are a direct fit to the Lanier LD140csr that I'm working on?
                      BTW PR guy said it was a connector fitment issue.
                      Best I can tell and despite the tech support advise, I'm thinking the will work fine.
                      If you have hands-on knowledge please advise me.
                      Thanks so much for all your help.
                      Jeff
                      • fshead
                        • 2376
                        I too have been there with the older b/w copiers and have a few mpc300s i am going to work on.
                        I will tell when i check my savin vs ricoh,but i think they are all the same on these units..
                        worse case you have to pull the harness and td sensor,which i ve yet to do..
                        I have two sets of SPC430DN drums that I know I will figure how to work in the c300/c400 series..
                          • 37488
                          Jeff
                          There is no difference between the Ricoh MP C400SR, the Savin C240SR and the Lanier LD140CSR other than the model sticker on the front. The only model I have worked on that had fitment differences between Ricoh and RFG models was the Lanier 5455/5470.
                          • Foo
                            • Nov 2009
                            • 199
                            Thanks...I think I'm confident in ordering a set and seeing what happens.
                            I be back and let anyone left wondering what happens.
                            Jeff
                            • Foo
                              • Nov 2009
                              • 199
                              Parts are ordered...
