Scanning from MPC 300
  • yormets
    • May 2009
    • 336
    I don't know what mi ssue is with Ricoh. I cannot get any Ricoh to scan to a folder or by twain driver or SMB. I can set up Canon's, Sharps, Toshiba's HP's but CANNOT get a Ricoh to scan. I down load the twain driver..extract it....where does it go. Can't find it anywhere. Not by searching or any other method. I download the file. I open it up. It says RUN. I click run and it extracts quickly and disappears. To where? Under what? If I search the folders and files it doesn't have any reference to any ricoh whatsoever. I already have it network printing. That took two minutes. I've now been trying to scan for three weeks using all different methods. Can't get anywhere. Help!!!!!!
  • sandmanmac
    • 3981
    Re: Scanning from MPC 300
    Hmmm....Groundhog day's not until tomorrow, but I thought this sounded familiar:
    http://www.copytechnet.com/forums/ri...ht=#post586812
    Seems to me you should get together with someone who DOES know what they're doing and have them walk you through, because many of us have already been down this road with you without success....
      • 37488
      Sounds to me like you do not have administrator rights on the computer you are using. Either that or you are getting a background popup requesting administrative permission. Try this, download to a separate folder. Open the folder and Right-click on the file, select Run as administrator. If you get a prompt for administrator credentials then your login does not have administrator rights. You will need to contact your IT department to install the TWAIN driver or setup scan to folder.
      • yormets
        • May 2009
        • 336
        I officially give up. I was trying to do it onsite. This time I brought one into my office hoping for better success. I called our local ricoh guy. I surrender. Nothing is this hard to do.
        • mikadonovan
          • May 2008
          • 2931
          The firmware must be up to date to work with the latest OS versions. If it is not, you're pissing into the wind, as it will not work.
          NEVER ASSUME ANYTHING
          • copier tech
            • 8144
            Yes there was a firmware release for this issue many moths ago.
            You could sent up scan to email as a work around.
            • AjitN
              • Mar 2009
              • 287
              I down load the twain driver..extract it....where does it go. Can't find it anywhere. Not by searching or any other method. I download the file. I open it up. It says RUN. I click run and it extracts quickly and disappears. To where? Under what? If I search the folders and files it doesn't have any reference to any ricoh whatsoever. [/QUOTE]
              DO you mean to say that when you extract the downloaded file, you are not able to locate it on PC? & that is why you cannot install twain driver?
              Well Well, something is very strange.
              Normally it gets extracted to C drive in temp folder. you can see the folder having the same name as of downloaded file name.
              As far as scan to folder create folder on PC with admin rights & shared it for 'Everyone'.
              On machine using 'address management' select New Programme & establish the path to the shared folder on PC.
              Hope this helps.
                • 37488
                Hope this helps.[/QUOTE]
                My experience is that the TWAIN download is a self extracting executable that extracts to the folder it was downloaded to and then automatically executes the install program. It is best to download it to a separate folder with no other files in it. You must have administrator rights on the computer. It also must be run in 32 bit mode.
                The reason for using a separate folder is once it has been extracted to will contain only the TWAIN files and the original download file. The contents of the folder can then be copied to a SD card for installing on another computer.
                • copier tech
                  • 8144
                  Why are you going down the route of using twian to scan, are you are connected to the printer via USB?
                  Scan to folder/smb is much simpler.
                  Or as I said earlier scan to email.
                    • 37488
                    Hope this helps.
                    My guess is he does not know a login name and password that have the necessary rights for scan to folder. Lack of rights also blocks installing TWAIN drivers.
