Good evening
I have a Ricoh SP4100 NL which reports the next error
Remove internal jam path / Open
Front cover
Inside, however, there is no jam
Removed sensor, clean, but the problem persists.
Can you help me?
I can print only from the bypass and not from the drawer 1.
Tray 1 has nothing broken.
Is there any way to reset this error?
It signals jamming when print from tray1.
Under normal conditions the printer does not report jams
Thank you
Front cover
Can you help me?
Thank you
