Ricoh 4100 Internal Jam Error
  • printertnc
    • Jun 2015
    • 68
    Good evening
    I have a Ricoh SP4100 NL which reports the next error
    Remove internal jam path / Open
    Front cover
    Inside, however, there is no jam
    Removed sensor, clean, but the problem persists.
    Can you help me?
    I can print only from the bypass and not from the drawer 1.
    Tray 1 has nothing broken.
    Is there any way to reset this error?
    It signals jamming when print from tray1.
    Under normal conditions the printer does not report jams
    Thank you
    • 37405
    Re: Ricoh 4100 Internal Jam Error
    Internal jam can be anywhere that the paper cannot be seen without opening something. Opening the front cover and, on some models, removing the imaging unit will reveal anything between the registration roller and the fusing entrance. Since the bypass works, the jam is between the paper tray and the registration roller, pull out the paper tray and check for a sheet of paper fed out about 1 inch or with a smudge where the feed roller has turned against the paper but not fed it out, dirty or bad feed roller.
    • Iowatech
      Not a service manager
      • 3930
      Originally posted by printertnc
      Good evening
      Front cover
      Can you help me?
      Thank you
      When printing from tray 1, where does the paper stop at? Just curious, as there's a tiny chance the rollers that feed paper out of tray 1 are worn out, or you've got some bad paper.
      • Techconnect
        • Jan 2018
        • 15
        [QUOTE=printertnc;592459]Good evening
        Front cover
        Can you help me?
        Thank you[/Make sure your re on the right switch use logging data of SMC report to be sure.
        • printertnc
          • Jun 2015
          • 68
          The paper on tray 1 does not even start, the rollers are ok, I changed the clutch but the problem persists.
          What can it be?
          If there is no sheet of paper in the tray 1 from a jam. But the card is not there
          If I turn the paper take-up roller by hand it moves all the part of the clutch so it's not a mechanical problem
          • TonerMunkeh
            Professional Moron
            • 3865
            Take the toner out and put the machine on it's back. Take the feed roller out. On the green push handle a little tab breaks off that moves the shaft away so you can change the roller. If this little tab is broken, the feed shaft isn't pushed back into position to drive the roller. Also, there are two sensor actuators that can break or come off. Check those. Is it also detecting the correct paper size?
            Hit it.
            • printertnc
              • Jun 2015
              • 68
              Hi
              Great News!!!!
              Problem risolved
              Changed the Sensor And Paper Feed Clutch.
              Thanks to all!!!
              Bye
