Ricoh pic question
  • alliedofficeproducts
    • Jan 2015
    • 92
    [Misc] Ricoh pic question
    I have a Ricoh mp2510 that is displaying change photoconducter unit, usually no big deal. The pcu in the machine has a green carry handle. The one I had on hand was the one I use in the mp2550. I installed it but the message would not go away. The machine works otherwise. I noticed a small gear on the back of the green handle pcu that the other does not have. I can't seem to locate this green handle type. Does anyone know the difference between the two or the part number of the green handle one?
    • 37560
    Re: Ricoh pic question
    The one with the green handle sounds like a Type 1027. Originally used in the Aficio 1022/1027/2022/2027. The small gear has a flag on it that rotates to activate a reset switch on those models. On the later models the PCU can be rebuilt, PM kit available. The 60K PM counter needs to be reset in SP mode, refer to the service manual.
    • hattrick
      • Jan 2018
      • 2
      Run developer initialization and the message will go away.
      • fshead
        • 2376
        the flag on the rear drum unit would activate a photo sensor on the rear frame..
        you could take a piece of paper and insert to trick it too and machine would reset and recycle
          • Jan 2015
          • 92
          Great thanks. If I order the 1027 does it come with developer preinstalled?
            • 37560
            It should.
              • Jan 2015
              • 92
              It should.
              Thanks, you're a scholar and a gentleman.
              Sent from my LGL41C using Tapatalk
                • Jan 2015
                • 92
                Thanks to all for the quick replies. It's greatly appreciated.
                • fshead
                  • 2376
                  with these units drum and developer there is zero extra room in the developer unit so if it was shipped you might have one side of the developer units packed with developer and little on other side..This could happen if it sat standing on its front or rear side..
                  S o laying flat as if in the machine, you might want to gently shake it side to side ..
                  • hossam
                    • Aug 2010
                    • 70
                    you can disable PCU Alarm in service mode
                    sp 5912-1 0: Not displayed, 1: Displayed
                    sp 5912-2 Note: The zero setting switches the alarm off.
