can I scan to folder wth windows 10/8 with the firmware on this mpc3002?
  • fshead
    • 2376
    hi
    I have to be able to scan to windows 10 and 8 for this account that i just finished getting this used machine ready to deliver..
    I have not asked for the latest for the mpc3002 as i dont want to come off greedy.
    Therefor if what is loaded here is plenty I wont have to deal with a long set up.
    thanks in advance..........
    • 30389
    Re: can I scan to folder wth windows 10/8 with the firmware on this mpc3002?
    If its more than a couple of desktop use scan to email. If not use filezilla server ftp.
      • 8192
      Try a test scan with your own win 10 laptop before you install it, if smb scans fails you'll only need a fw update much easier to trouble shoot before you get it onsite.
        • 37556
        Originally posted by fshead
        hi
        [ATTACH=CONFIG]38796[/ATTACH][ATTACH=CONFIG]38797[/ATTACH]
        Instead of trying to take pictures of the display with all the glare that has why not use SP 5992-005 to export the Diagnostic Report to a SD card and attach that or print SP 5990-005 ans scan it. Either way we get a one page PDF with all the firmware on it. That being said i it does appear that you have NCS v 11.96 which supports Windows 8 and later. With the latest Windows security updates you may have to enable SMB 1 support, provided of course that the customer's IT will allow it.
        • fshead
          • 2376
          thanks i couldn t print out due to 20 degree temps in my non heated garage..
          i pulled the machine inside and let it warm up and this is my FW.
          • fshead
            • 2376
            Set up scan to folder with out any FW updates and works without a hiccup......
            thanks
            • TechnicalSupport
              thanks
              you need firmware update
                • 37556
                Wrong. He already has all the current versions needed to scan to Windows 8 or later.
                • fshead
                  • 2376
                  IT seems TechnicalSupport will call me "friend" and sell me
                  any firmware..............
                  • mikadonovan
                    • May 2008
                    • 2931
                    Apparently not.
                    NEVER ASSUME ANYTHING
