MP 9000, intermittent Black stripes on prints and copies
  • Codex
    • May 2008
    • 661
    [Misc] MP 9000, intermittent Black stripes on prints and copies
    Hello
    We have a MP 9000 with a strange problem, sometimes during print jobs the machine prints a sheet with random black stripes , we found no logic behind this because it prints the sheet randomly, sometimes after 5, sometimes after 500 prints, already swapped Hard drives, and changed every switch or network cable in the room, because we thought it was a kind of interference, but nothing....any ideas??
    Memento Audere Semper
  • andy227
    • Jan 2013
    • 219
    Re: MP 9000, intermittent Black stripes on prints and copies
    Looks like a laser issue to me. Polygon doing weird stuff. Check in the SC's log if any laser codes have been generated.
      • 34783
      Seen similar with board problems. BCU, IPU, Controller
      • Polarbear
        • Feb 2012
        • 1070
        Have you swopped controller memory?
        Otherwise I'm with the previous posts relating to laser and ipu.
        Especially ipu as that is what creates the image for the laser.
        Sent from my SM-G925F using Tapatalk
        Press the GREEN button!!
        • billak
          • Mar 2010
          • 5
          Reseat connectors on pwb's.
          Στάλθηκε από το ONEPLUS A5010 μου χρησιμοποιώντας Tapatalk
          • Mark Bbb
            • Jun 2012
            • 1662
            i have seen some overheating problems in the scanner cavity due to very high volume of scanning activities with al kind of weird problems.
            Also it could be a ground wire problem...
            • Mark Bbb
              • Jun 2012
              • 1662
              Forgotton to mention: it's not only a wire that keeps contact to "ground", there are also little metal plate on the PCDU (there are several of them) that can cause this issue.
              • Zeldaman
                • Mar 2011
                • 946
                Hi there!
                Had exact the same issue on an ALEX : 1. randomly, then permanent. It was trhe IPU-board.
                Greetings...
                • Codex
                  • May 2008
                  • 661
                  Hello
                  I tried to change IPU, Laser Diode, Polygon Mirror, SBU, CCD, but i still have the problem with intermittent Black stripes
                  Any oyher ideas?????
                  • Polarbear
                    • Feb 2012
                    • 1070
                    Originally posted by Codex
                    Hello
                    You say PRINT. Do you mean print from PC? In that case controller would be next to swop.
                    Sent from my SM-G950F using Tapatalk
                    • Codex
                      • May 2008
                      • 661
                      The customer says the problem occurs in print from pc and copy
                      Inviato dal mio SM-G935F utilizzando Tapatalk
