mp4000 mp4001 mp4002 cleaning web not rolled-up
  • Batman1976
    • Jun 2016
    • 91
    #16
    Re: mp4000 mp4001 mp4002 cleaning web not rolled-up
    the purpose of the cleaning web is to clean the fuser roller. WHY in the world would you NOT put in a part that a DESIGN ENGINEER got paid to design and incorporate into the machine?
    Running without a cleaning web will cause PQ/CQ issues
    Believe me having looked after 60 of these devices in one building and running into a lot of cleaning webb issues we found they will run perfectly fine without them installed if they aren't doing heavy coverage. Saved a lot of time and money to just remove the webb unit.
    • Mark Bbb
      • Jun 2012
      • 1662
      #17
      I have experienced that the modif cleaning web gives a better performance then the old one: 150K.
      It rolls up fine, so no more jams...
      I have also find a way to replace the web film: when you reinstall the pressure plate bar, first loosen the screws of the pressure plate, then place it on the unit and then tighten the screws back on...
      Good luck!
      I replace F.U. when it is broke. Minima 750K!
      Development unit: referbish by removing the agitation bar completely and clean the grid of it well, 140K
      Also PCU: clean it well and replace parts, 140K
      Good luck, boys!
