address book move ricoh to kyocera
  • LNorris
    • Sep 2008
    • 645
    is it possible to move the address book from a ricoh to a kyocera?
    • 37433
    Re: address book move ricoh to kyocera
    After you backup the address book in WIM, I believe that Ricoh has a utility that will convert it to a CSV spread sheet. Tech support talked me through it a few years ago when I had customer who wanted to import the address book from their MFP in a LAN FAX driver.
    • LNorris
      • Sep 2008
      • 645
      device manager nx lite (ricoh), i found to d/l the ricoh address book, supposedly kmnet viewer for Kyocera will import, but havent found the option to do that yet.
        • 37433
        May need to ask on the Kyocera forum how to import and what file format it need to be in. Maybe PM someone like blackcat4866.
          • 23002
          I've not had much luck with that. Kyocera addressbook backups are encrypted, and require the special utility to edit or convert for another Kyocera format (different model different encryption). It is not ever in the unencrypted simple CSV format. =^..^=
          • mincopier
            • Dec 2015
            • 289
            When using the Kyocera Netviewer you must choose the "Multi Machine" option. Watch the options carefully as there is three. Eventually you should be able to get to the csv import. The Ricoh Smart Devie Monitor is still available on the service side of the site. I prefer it over the Device Manager NX myself.
            • aktasson
              • Feb 2017
              • 201
              It's not work at direct way. You have to create a kyo conform net viewer csv file.
              It's take time to edit and filter (import) the ricoh adressbook format to a semicolon separated file in notepad++.
              I suggest you to copy and and paste from WIM to the Command Center on the fly. The customer pays that. This is an extra and
              the customer has to pay for the extra work. If the customer only has 10, 15 adressbook entrys so then the special editing work is not worthwhile.
